Looks like my past good fortune with bell-housing alignment has come to an end with this 66 Satellite. I’m .0065” out L to R and .0045” out up and down. Bell-housing need to move towards 4 o’clock.
What’s the easiest way to remove the existing dowels. Engine is in the car. Drill, tap and push them out with a small bolt? Do they drill pretty easily?
Also, I didn’t have all the bolts in and fully torqued but my OEM flywheel seems to be a little low on one side - .005” runout. I’ll re-run when I get my ARP bolts in for a recheck. FSM says .005” is max limit so I could just leave it alone. Or I could get some .002” shim washers and shim the low side out .002” on 2 bolts and .004” on 2 bolts in between the .002” bolts 8-bolt crank. I don’t want to have the flywheel surfaced as it’s within service limits right now but only by .010-.015” right now. It’s a one year only flywheel and replacements aren’t available per Brewers. In a discussion on service limits they advised to do as little as possible to it and just run it. So shim washers are probably my best option to correct or just run as is. Are shims a bad idea?
Thanks
Thanks
