Best gas proof sealant for wires passing thru fuel sender base
koosh
2:33 PM
CT
Any suggestions for the best gas proof sealant to use for wires running into fuel tank for in-tank pump?
A cake of hand soap will work wonders for sealing gas leaks.
A little bit of water and make a thick paste - then mold it around the leak area or seal and let it set. :thumbsup:
There are bulkhead connectors made for this purpose. Google "fuel pump wire bulkhead" and pick a style that you're comfortable with...
Aircraft Spruce carries a fuel tank sealant called Pro Seal. Sealed my aluminum tanks in my airplane with it. It's a 2 part mix. You would have to buy a qt.
Seal-All is the best sealant for all kinds of fluids. The main ingredient is magic.
I have used seal all on a motorcycle gas tank. Worked great.
My sending unit for the fuel gauge is now on the top of my tank. But the fuel pick up still exits from the side, about half way down. It has a calk style gasket. Not sure what goop I used.
We're not building screen door boats here.. he's got a fuel leak!
my bad......
