best oil for 727
2dht
12:36 AM
Finland
So, what would be the best trans fluid for 727?
Chrysler's ATF +3 isn't made anymore now it's ATF +4... They have synthetic, but I wouldn't recommend it, found a regular, non-synthetic +4 at autozone, get that. It will be at any dealership too if you have one close by
I use a synthetic in my trans and I'm happy with her.Less friction in my eyes is better
The factory reccomends Dextron - I use type F in my race trans. I personally don't think synthetic is good for an automatic transmission.
Yeah I just say not to use synthetic because if he's just topping it off, I've always heard that mixing it with regular is a no no.
I wouldn't use type F to lube the hinges on my door! A lot of old racers used it and it is recommended in the old MoPar books, but that's for racing. The reason it's recommended for racing is because it has a higher friction coefficient and grabs better, which if some logic is followed, it doesn't lubricate as well. I would use Dextron in a street driven car, or I did recently get some SWEPCO 714 ATF but haven't tried it yet. My rep says he has a drag racer customer that runs the 30 WT and it works very well under the 800 or so HP the car makes. The SWEPCO stuff is designed to be used in the big heavy duty trannies like Allison and ZF.
I really like anything "Torco Racing Oils" makes for all of my race or higher performance cars, they have a great anti foaming agent & higher heat resistance/flash temperatures for cars with high stall speeds especially on the street {check it out on their web site} & Royal purple "Chrysler type 4" synthetic in my 99 Dakota 4x4 had great luck with both, used Red line products quite awhile back...
type f for me.
Thanks for everyone. Dextron III went in...
personally...i prefer some orange juice and some vodka,,,maybe a bit of sloe gin for color...{{{{{{.shaken}}}}}....not stirred of course!
