Best spot weld cutter
dodge68charger
2:37 PM
Washington
Looking to drill out a bunch of spot welds on my car. Can anyone recommend a company who sells a good cutter. Thanks
Blair Rotabroach for me.
Blair by far !!you can skimp and buy the cheap ones from harbor freight but you will go threw 3 of the cheap ones to 1 blair!! lesson learned first hand go with blair a little pricy but worth it in the long run !!
Thanks guys. Im gonna order a few today. Guessin 3/8's size will be okay
Everyone will say blair rotabroach.
I use the $19 cheap ones and lots of cutting oil without going crazy and can do about 50 welds with one double-sided cutter. I removed the entire cowl with one cutter and no issues (not including the seam welds and the lead of course). You have to go straight and MUST use cutting oil.
Blair is the professional model and I don't profess to be one.
Randy
cutter
blair always, get the blair lube also, and don't go 500 miles per hour when drilling. I think I have used 10-12 cutters in 20 years. buy a good automatic center punch to mark the weld before trying to cut.
pt in tennessee
