Best Wiring Harness?
dodge68charger
6:08 AM
Washington
Going To Wire Up My Superbee.. Pretty Much All Stock.
Should I Go American Autowire,
Ron Francis, Or Painless??
Goin With a One Wire Alternator, Just Worried About The Headlight, Heater, Wiper Motor Switch Wiring.
If you are staying stock, then go with M&H harnesses from year one. If you catch a 30% off discount code it will be good. I did my 73 and couldn't be happier.
I went with Ron Francis in my 65 coronet, exceptional quality and great customer service.
M&H is plug and play. The wire color conforms to factory diagrams, the wires are cut the correct length and the connectors are the right type and pre-installed. It's a simple installation. I can't speak for the others.
I also used Ron Francis and agreed very good quality and very good customer service!
The harness at Year One is currently “discount exempt” and “not eligible for free shipping”.:bs_flag:
I replaced all wiring harnesses for my Coronet, which are from M&H.
No fitment issues, as OEM with correct colour coded wiring and correct length.
Got them at Classic Industries.
what do you guys think of kwik wire? Anyone use this? i like the coil cut-off switch. Aside from the American Autowire kits that seem to have all new plugs, how do you guys use the others? You remove the old plugs from the old harness and re-use them?
That was one of the things that bothered me about the other aftermarket kits. How many connectors would I need to buy...
Agreed, think i'll go with the American Autowire, by the time your done replacing all the plugs with the cheaper kits, you might end up at the same price, the advantage is less work. Just have to figure out how to do the coil cut-off, i like that...
