- 9:09 PM
- Jul 9, 2019
- Modesto California
Actually you machine the side of the rocker where it butts up against the rocker hold down... Typically the rocker hits the pedestal/hold down before the tip of the rocker aligns with the valve... The solution is to narrow the rocker where it rides on the shaft... Only cut the side that rides on the pedestal/hold down... Some guys simply grind the side down... But that risks the surface not being parallel which causes the rocker and/pedestal/hold down to wear at the contact point... A simple jig lets you cut them on a lathe assuring they are square/parallel... I actually intentionally cut them about .050 thin so I can shim them allowing me to put the alignment spot on, and the shim reduces wear to the other parts.., you also said some machining may be needed on the tips where they contact the valve stem ?
