Big block adjustable rocker arms
Oiling holes are normal and necessary. Just use some 320 paper and light oil to clean up the fulrum area. I believe those have the good old adjusters. I think they'll last longer if you use some induction hardened shafts.
Thanks. I only have one with an adjuster.
I opted to use spacers and not springs. Took a little longer to do but I won't have to worry about them moving. I think it was .005 clearance between the rockers. Had to trim the hold downs too to center the rockers just right.
Run a brake cylinder hone through them, they should clean up
I ran Harland Sharp hold downs with spacers. I ground them where necessary to center the tips
