FOR SALE Big block ATI Super Damper w/Chevy pulley pattern
PsyOps
3:42 PM
Pacific NW
Feedback: +3 / =0 / -0
This is for an internal balanced big block Mopar engine when using a front motor plate. It uses a Chevy pully which keeps the belt alignment with the stock Mopar water pump pulley which is pushed forward by the width of the motor plate.
ATI propaganda: "Patented ATI Super Damper standard harmonic balancers are the only crankshaft dampers designed exclusively for high performance engines. Outer shell in aluminum and contains a steel inertia weight. The inertia weights have six (2-ring design) computer-machined grooves to retain the proper durometer O-rings (dyno tested for each application). Features include:
* Eliminates torsional crankshaft vibrations
* Exceeds SFI 18.1 specs
* Black zinc chromate finished
* Tunable, rebuildable, and extremely efficient at all rpm
* Laser-engraved 360 degree timing marks"
This one is not available at Summit, I haven't looked anywhere else for a retail price. $279 + minimal shipping from 99201. PayPal F&F (or add 3% for Goods/Services) or postal money order.
