Big Block heads
I too would be interested in hearing exactly what was done, what new parts were installed, and what the final cost was.
Along with what part of the country the shop was located in.
No judgements...... just curious.
All valid questions. Skip to the bottom to see the costs.
Here is my cost to re-do a set of small valve 915's. I disassembled them myself and reused the intake valves, locks, & retainers (retainers might have come from a different set of heads I think). The 1.74" exhaust valves came from Rockauto I believe & were $70 after taxes + shipping (these might have come with new locks). The valvesprings I purchased used for $50, part number: P3690933, though stock springs would have worked for my cam. (already had these springs, so might as well use 'em). The new seals came with a full engine gasket kit.
The machine shop was C&P in Fort Wayne Indiana. I had them clean, magnaflux, surface grind, new guides on all 16, new oversized hardened seats on the exhaust, grind the seats and set valve height on all 16, & they also installed steel core plugs NOT per my request & charged for it.
I spent $7 on a can of engine paint for the heads. I also used a miscellaneous amount of brake cleaner to clean out the oil feed holes if you want to count that.
To answer someone else's question(s): Nothing trick about the valve job, the guides were whatever they deemed to be "quality".
That's all I can remember, the bill isn't in front of me but its in my Excel budget sheet:
$70 exhaust valves
$50 springs
$643 machine shop
$7 can of paint
$770, true cost, ready to bolt on and run.
For comparison, new heads from 440source, out of the box after tax + shipping are $1120 BEFORE any checking/corrective work has been done to them.
Here is what these heads were for: a smog era 400 short block in a beater E-body with 3.23 gears and stock converter. Headers, Summit cam, stock style dual plane, 750 holley.
Just a basic street combo that isn't going to light the world on fire. With my current deck clearance & an .020 gasket, compression should be a whopping 8.4:1 assuming my heads are about 80cc.
