No one ever oils the advance cam, and this is the results.
i've tried all kinds of stuff and the results seem to be the same; the grease dries up.Lou,I have been using white Lithium for years and never had a problem,same with the breaker plate.
Bingo oil the felt with a few drops of motor oil every 12k keeps it all lubed under the plate (weight, springs, shaft). A lot of us do not know that.Oiling that little felt circle was standard at tune up time-every 12,000 miles in the old days. Checking both advance systems was also included.
Mike
Not sure what the name is, but on aircraft magnetos, a 'non-sling' type heavy grease/oil is used. It's like rear axle lube.what's a good lasting lube?
No, not Lubriplate.Lubriplate?
I just punch them out of felt how many you want just .43 for the ride!I have yet to find a felt pad in a reman distributor. Can you buy them new from someplace?
you have a mallory dual point for 383 eng lubed and ready to sell?I just punch them out of felt how many you want just .43 for the ride!
I believe I do I am not home right now but will check later today when I get home.you have a mallory dual point for 383 eng lubed and ready to sell?
