- 2:49 AM
- Oct 16, 2014
- Salisbury, Vermont
^^ Coronet is 3 inches or so shorter than the 67 Coronet. Is the difference in the quarter panel length aft of the wheel well? Thanks.
Identical.
To me the 66 looks longer.
Especially a 440 model with horizontal trim midway up the side.
That trim does a LOT to fool the eye into thinking a vehicle is longer.
Rocker trim does to.
Trim on 67 at the bottom body line does a little but not as much.
67 has those "scallops" on the quarter. Similar to a 66 500 trim.
Might cause the eye to think "bunched up".
I've always thought that 1 inch wheelbase difference was BS marketing to suggest that the Dodges were a higher product line than the Plymouths.
I've heard the spring hangers are different, and that's where the inch is, but haven't seen it.
That would be the obvious place since the floor pan is the same, the springs are the same and the frame rails are the same.
I suppose since I have both now, and they're unmolested, I should measure.
