bought mine in 2017 early and it does not.
As I recall, there are 4 master splines on the output shaft. The pitman arm can be mounted in one of 4 positions. Each 90 degrees apart. So once you have the box centered, only one of those 4 positions will be correct. The correct position will have the center link end, inline directly aft of the output sector shaft.MoparGuy68; Just curious. Does the Borgeson box utilize a master spline; that is, one spline thicker than the others so that it locates the pitman arm?
You are answering someone else's question about the master spline. It was coloradodave who asked that.You are persistant! It will be worth it in the end. These gear boxes are a really nice upgrade from stock.
The input shaft does not utilize a master spline. I'm not sure why Borgeson never did that. The centering is like 1.870 turns each way from center to lock.
You can tell when the box is centered, the pitman will be in line front to back from the box to the center of the joint at the center link. Also, for god sakes put the hammer and pickle fork down. OTC makes a tool set for a $100 that is all pullers. You can separate any joint without ruining the boots, your car or your hands!
For the others, here is a shot of the cooler I sell. It has integral brackets that make mounting look factory.
I’m going to assume you’ve loosened the firewall plate in your attempt to center the column shaft within it’s housing. The photos don’t show the plate maxed out. The holes under the silver washers are pretty large.
How are into the coupler is the shaft?
I'll send you an email regarding my theory of why my column may be inserted further than stock into the coupler. Maybe that might have something to do with the small gap at top too..Since you say there was a small gap at the top of the column even with the old box, it sound like there is something else going on here.
Regardless, you can try adding a 1/8" shim at the top bolt of the box to tip the input down slightly. This may help. The column mounting isn't bad from a design stand point. It allows lots of adjustment, its collapsible and its break away for accident protection.
Happy to listen. There is a spec of the suggested depth the little shoes. If the are in to far, it will bind on the column shaft.I'll send you an email regarding my theory of why my column may be inserted further than stock into the coupler. Maybe that might have something to do with the small gap at top too..
Why should the cooler be mounted sideways? What’s bad about mounting it vertically like I have it?All looks good, except the cooler should be mounted so the hoses come in and out of the side.
