brake booster push rod adjustment
desbolib
6:21 AM
hamilton ontario canada
I want to start by saying I love it here.I have finally found out the brake problem with my 70 charger.It is the pushrod length.When the master is installed it pushes the rod in about !/2 an inch.From what I have read it needs about a 1/4 inch freeplay at the end of the rod.I have also read that there is a way to adjust the length of the rod.If there is anyone out there who can help me I would really appreciate it. thanks
Well, we love you being here!
The end of the push rod that goes into the M/C should have a threaded tip that looks like an acorn nut. You will need to hold the rod with one wrench and make the adjustment with the other. I'd say 1/4" is way too much clearance between the tip of the rod and piston cup. I don't have the actual specs handy but should be more like 1/32" - 1/16" or even less. I just replaced the power booster on a 69 GTX and I had to make a shim between the M/C and booster to get the small amount of clearance required.
thanks
thanks for the info.I have adjusted the rod but now I have a problem with the m/c.I am going to start out with all new and go from there again thanks for the info
just doing a power brake conversion on my car and the used booster i got , when i install the master cylinder there is about 1/4 inch gap between the booster and cylinder until i tighten the bolts , so the booster pushrod preloads the master cylinder about 1/4 inch, i am having issues bleeding, i am getting nothing out of the rear of the master cylinder , is this too tight and causing my issue?
No preloaded like mentioned above a scant amount of play to about 1/16" good to have a little play in the pedal to booster also a vacuum plug on the brake light switch will keep it from rattling..
