I am removing my brake booster. What is the best way to disconnect the lever pushrod assembly. In the FSM says to remove the lower pivot bolt not sure which they are referring too.
Do I need to also remove the pushrod nut and bolt?
It’s very tight in there with the bracket surrounding the bolts.
Thanks for your help on this!
Ron
Ron
