RRChris
I have a 71 Satellite with Power Front Disc Conversion, using a general purpose 8" dual diaphragm booster.
The brake system has been fully rebuilt - new rear wheel cylinders, front calipers overhauled, new hoses all round, new master cylinder, and new booster. The booster pushrod to master cylinder is confirmed as the right length. I have also gone through the pedal linkage and ensured that everything is free to move. Brakes have bled well and pedal feel is good.
As I drive the car the pedal does not always return back to the at rest position. This seems to get worse as the car is driven longer. From time to time you can feel the brakes dragging. If I put my foot behind the pedal and lift up it releases - telling me that it has to be between the pedal and the booster (no direct mechanical link to the master cylinder). The booster holds good vacuum. Is it possible the booster has an internal problem? Can the booster get hot and tight to operate? Has anyone experienced similar before? Any tips would be welcome before I spend more money chasing guesses.
