Dananator
I have a 67 Coronet 500 with a 426 hemi. Bought it as a unfinished project. I completed it and one thing I was advised to do was put disc brakes on the front. I found 1973 Roadrunner and used the 11 3/4" discs on my car. I used the origonal calipers (rebuilt) and rotors and masteer cylinder. I noticed the master cylinder on the 67 was the same number as on the 73 Runner. After installing the brakes I noticed when I backed up the pedal would go to the floor, I pump it once and it would be hard as a rock. I took it to two mechanics and a brake place and had them bleed the system and adjust the rear brakes. No change. I chedked the rears and no actually adjusted them so I adjusted them a little on the tight side the problem dissapeared for a while but once in say 15 trips it will still let the pedal go to the floor. No once can figure this one out. I put a new master cylinder on and I checked the rear pistion diameter on the rear wheel cylinders and they are the same as th Runners 15/16" bores so the componets match the factory setup so what is causing this? I have a Dana 60 rearend with 4:10 gears. If you have any idea what is causing please pm me or reply to this tread! HELP
