Mariposa Mike
I have an on going thread on brake problems (Smokin Brakes) but have a different question on brake shoes. I found rear shoes for the 66 Charger that have the correct location for the springs and e-brake hole. Meaning it has a hole and not a slot for the cable mounting. But when I ordered front shoes I was given the slot type which means I would need a longer spring to mount them. They were also a different part number but look the same as what is on the car.
So...the question is are the 10 inch drum brake shoes the same front and rear? And if so, how do we get the front shoes to do more work that the rear? Is it in the wheel cylinder size/bore?
If so then I'm reasoning I can go back to the parts store and ask for another set of the rear shoes. Of note, I found one of the self adjuster springs loose in the front. I believe it's due to the spring location and the amount of tension on the adjuster spring due to the different shoes.
Inquiring minds want to know. Can't trust the parts book at O'Reillys.
