Good news first. I got things assessed and determined that the oil pressure gauge hose was definitely the cause of the fire. I will replace the engine and light harnesses, but the outer wrap was all that was destroyed in a few spots. After careful examination none of the wires had insulation damage. I changed out the starter relay and the positive cable will need replacing, but all was okeedokee enough for a cam run-in. Started right up, no issues...temps were good, water never got over 186 and header temps at the ports were all between 400-500 once it was heated up, no red-hots..sounded good, smelled good, and then....
Now, we had looked underneath periodically to make sure all was good (which it was) but towards the end of the break in time my bro yelled out "OIL!" and I saw this:
Definitely positively coming from inside the bellhousing. Beautiful, gold, 15-50..
As I moved to shut down I shot a quick vid of the pressure gauge (Hard piped to the engine this time you will notice
So....I got 25-30 minutes of run-in time on the cam & lifters so I'm callin' that good.
I will not, go through the drama of replacing the rear main from under the car when I can't confirm that's the problem. Blew low pressure air in and got some oil but just can't be positive where it's coming from...Cam freeze plug, galley plugs, or (ick) rear main seal....so out she comes.
If it's the seal the builder's gonna re-do it. I'll fix plugs to save myself the hassle of transporting it but oh boy he's gonna hear about it either way!
