Brighter replacement bulbs for 1157
coloradodave
2:10 PM
Lincoln, CA
A while back I believe 'slant6dan' posted the number for a Honda bulb that replaces the 1157 (tail/brake), but is much brighter. Anybody recall the number?
I saved the post, if you want the full post let me know.
In the early '70s, the 1034 was replaced by the 1157, the 1073/1141 by the 1156. These 1150-series bulbs put out the same amount of light, but draw slightly more current and last quite a bit longer. When changing from 1034s to 1157s, often it was (and is) necessary to replace the turn signal flasher, because the original would flash too fast if used with 1157s. Nowtimes, it's difficult to find a flasher calibrated for 1034s.
So, what to use for upgrade bulbs? Well first, here's what NOT to use: 2057s! People sometimes assume that because it's a higher number, it's a brighter bulb. No. The difference between 1157 and 2057 is in the "minor" (dim parking or tail) filament. On the 2057, the dim filament produces 2 candlepower. On the 1157, the dim filament produces 3 candlepower. The difference doesn't sound like much, but it's very large as a percentage. Both 1157 and 2057 produce 32 candlepower from the bright (brake or turn) filament.
Though they are spendy, the best bulb you can use in place of 1157 is a 3496. You can get them from your local Honda dealer. Part number is 34906-SL0-A01. It draws the same amount of current as 1157, but is much more efficient. It produces 43 candlepower on the bright (brake or turn) filament, and 3.5 candlepower on the dim (tail or parking) filament. It also has a nickel-plated base that is much more corrosion resistant than the plain brass base of an 1157, so it's less likely to stick in the socket.
