Bug removal from front end of our old cars??
hunt2elk
10:19 AM
WI
Have you guys found any magic formula that will remove dried on bug splatters that won't damage the paint? I always put the job of cleaning the bumpers, grills, and front ends off until covering up the cars for the winter, and it sucks.
I always try and get them off right away.
Even after a few days I've seen discoloration and paint deformation.
I do recommend ceramic coating (a good one like 3M or chemical guys) bugs come off much easier.
To clean dried bugs I start with a quick detailer and let it sit 5-10 minutes.
I use a cotton cloth with a little tooth to it a microfiber towel just moves stuff around.
If that doesn't work I use a cheap foaming glass cleaner and do the same thing spray wait a bit and clean something else.
Of course with just wax you've likely lost your wax in that area now.
Either A or B does the job.
It sprays on. It's a foam. Let it soak in and wipe the bugs off. It is a great window cleaner as well. You can find it at Wal Mart and Menards.
Thanks guys. I'll try the Sprayway first since I'll be at a Menards in the next few days.
It sprays on. It's a foam. Let it soak in and wipe the bugs off. It is a great window cleaner as well. You can find it at Wal Mart and Menards. View attachment 1945812
That stuff is awesome. It's a great degreaser and general cleaner, and also good for a final wipe if you're spraying paint or clear.
This is the way. My TTA car is ceramic coated and I use ceramic spray Detailer and they wipe right off.
This stuff is awesome. They also make a spray interior detailer that works awesome under the hood for detailing. All the houses and rubber shine up with just a spray and you don’t need to wipe anything off. Takes a couple of minutes to detail under the hood. They have 3 different versions, I use the interior detailer matte finish for the engine. I haven’t tried the high gloss or instant shine yet.
The best trophies are bugs on the windshield and chips in the paint...
X2 on Sprayway but use dryer sheets after you spray!
