FOR SALE BUNDLE DEAL - MOPAR, MSD, HOLLEY - B Block & Parts
lionsdrag
New Member
11:28 PM
Orange County, CA
Feedback: +0 / =0 / -0
Build/Rebuild Your Engine with this B Block & Parts Bundle!
La, Habra, California 90631 (Southern California) - Must be willing to pick up
$7,495 OBO
Accept CASH, Cashier's Check
https://www.facebook.com/marketplace/item/2226832250945731
NEW/PACKAGED ITEMS
MSD 3301 - Silicone Straight Boots & Terms (4 of them)
MSD 3322 - Straight Socket Boots & Terms
MSD 3330 - Boot Reflector, Straight, 2 each Pkg (5 Packages)
MSD 3331 - Coil 90 Degree Boot & Term
MSD 3410 - Capacitor
MSD 3414 - Cylinder Markers, 8.5 mm Wire
MSD 3415 - Shrink Sleeve Numbered for Cylinders (2 of them)
MSD 34019 - Super Conductor Wire, 25 feet Bulk
MSD 34039 - Super Conductor Wire, 6’ Bulk (15 of them)
MSD 3503 - 8.5mm Wire Mini, Stripper – Crimper
MSD 3505 - Multi-Purpose Heavy Duty Crimping Tool
MSD 3509 - Crimp Jaws, Weatherpak, Fits 3505
MSD 6200 - Multiple Spark Discharge Ignition (2 of them)
MSD 6520 - Digital 6 Plus Ignition (2 of them)
MSD 8203 - Blaster 2 – High Energy Coil
MSD 8210 - Automatic Coil Selector
MSD 8212 - Firewall Feed Thru, Black (2 of them)
MSD 8213 - Coil Bracket (Ignition Products)
MSD 8223 - Blaster 3-Power Tower Coil
MSD 8252 - Ignition Coil, E-Core, Ok use with MSD 6
MSD 8253 - Ignition Coil, HVC-2, 6 Series (2 of them)
MSD 8301 - Change Over Switch – MSD to MSD Units
MSD 8387 - Pro-Billet Distributor
MSD 8408 - Grey Cap w/ Alumin
MSD 8408 - Adapt-A-CAP
MSD 8680 - Adjustable Timing Control, MSD 5, 6, 7
MSD 8680 – Adjustable Timing Unit
MSD 8804 - Spark Guard
MSD 8830 - Noise Capacitor 26 KUFD
MSD 8805 - Power Towers - Spark Plug Wire Adaptor
MSD 8843 - Pro-Clamp Wire Separator
MSD 8850 - Power Towers – Boots
MSD 8851 - Chevy Plug Wire Retainer Boots
MSD 8933 - Rich/Lean Indicator
MSD 8934 - O2 Sensor Bushing & Plug
MSD 8935 - Heated Oxygen Sensor, 3 Wire
MSD 8964 - Engine Knock Alert
MSD 8967 - Oxygen Sensor Switch
MSD 8990 - Timing Light
MSD 8996 - Ignition Tester, Dis 1-4 Channel, Digital
Power Master 904 - Battery Isolator – 200 AMP
Power Master 578618 - Black Thermal Coat Alternator XS-Volt
Power Master 8-57539 - Black 200 AMP Chrysler Upgrade Alternator
Bosch 4418 - Bosch Platinum Spark Plug (3 out of 4 in pack)
APP 3924 - Autolite Double Platinum Spark Plug (4 pack) – (Two 4pks)
Nippondenso 9300 - Starter Chrysler Mini
Holley L-30416 - Holley Pro-Injection / Fuel Injection System (2 Barrel TBI to be used w/ 4 Barrel Carburetors)
ENGINE PARTS (New, Used or Refurbished)
NEW
1) Holley 8204 - Holley Carburetor (600 cubic feet per minute) / possibly 1965
2) Timing Gear (2 of them)
REFURBISHED
1) Chrysler/MOPAR Engine “B” Series – “Big Block “
400 CI / 335 HRSPR before any alterations
(1976-1978 – hand marking on it lists 1974, but it’s 76-78 based on Casting #)
Cast in September
CASTING #: 4006530-400-9
VIN: 5R127467
2) Torqueflite 8 Transmission
Automatic B/RB-Engine A-727 (Big Block)
261-5 (261 of 1975)
USED
1) Cylinder Head (2 of them)
CASTING #1: 2843906 6
CASTING #2: 2843906 3
2) Intake Manifold
For 413-4 “B/Big Block” Engine - Made between 1959-1965
CASTING #: 220600
3) Rocket Cover (2 of them)
4) Crank Shaft
5) Cam Shaft
6) Air Cleaning Housing
