I need more customers like some of you guys, I'd never run out of work...
Would you care to elaborate on that as to why?I need more customers like some of you guys, I'd never run out of work...![]()
There are so many good high zinc/phosphorous oils on the market I decided not to play chemist and let the professionals do it. Take your pick: VR1, Mobil 1 15w-50, Penn Grade, Shell Rotella T-4, driven, and others as mentioned...Oils with zinc tend to be more expensive versus off the shelf oil. Not that I'm a cheap bastard, just curious.
What do you all have to say?
As long as it is a "High Zinc" oil, you should be fine. I have never heard anything bad about Brad Penn.How's Brad Penn oil?
Because of the myths and you-tube misinformation. A flat tappet cam engine requires a "High Zinc" oil (whichever brand is your favorite) from break-in and on... I am just relaying proven technical information, and what you do with it is up to you.Would you care to elaborate on that as to why?
Its Penn Grade now.
I concur. I use only 2 oils and no additives in my 440's street and strip.Spend your moldy money. Amsoil Signature 10-40 in the BB’s. High Zinc.
I use to Use the old Kendall oils (before Brad Penn)And it used to be Kendall, it's still the same formula and still green
We just did yet another thread on this the other week. I contacted "Penn Grade" when "Brad Penn" sold to them and asked if anything was different. They placed my call through to one of the head chemist and he stated it's still the same as Brad Penn, still the same as the original Kendall.
I was about to break in my new flat tappet cam and asked about using an additive. He said it's already formulated with the proper amount of ZDDP and adding anything else will change the properties and could be defeating the purpose.
Sounds good to me. Cam break-in went great, checked everything 500 miles later, went to Penn Grade partial synthetic after the break-in, and alls good.
(Kendall Oil, Chuck Etchells NHRA F/C sponsored fame)
I never really ever had any issues
(albeit I'm not a huge fan of any paraffin-based oils, like those from Penn.)
before I got sponsored by Torko Racing, best oil I ever used
& for a while Amsoil, great product too
I use Royal Purple Synthetic in my DD's, 99 Dakota for about 15 years now
hydraulic roller camshaft & HS 1.7:1 roller rockers
(at $8.00 a qt it's far cheaper than many other synthetics & it's done very well)
Shell Rotella in the Powerstroke diesel
I still do use a break-in oil, with Phosphorous zinc
whenever I 1st fire any motor up
I figure it's not going to be in there long anyway,
it can't really hurt much
(newer engines, rollers (can be too thick, make sure to get the proper viscosity)
& computer control &/or catalytic converters or O2 sensors it may affect/effect)
If you're running any type of flat tappet camshaft
just make sure to do the proper camshaft break-in procedures
better to be safe than sorry
to each their own
even if it's just old school "hyperbole", it's never let me down
maybe all of the engines
Been using Brad Penn and now Penn Grade for the last 15 years and knock on wood, no problems.How's Brad Penn oil?
There is an auto salvage parts store a couple of towns away from me that sells it. Wasn't that long ago they were getting $50/case. The last box of it that I bought this summer was $62, and they mentioned that it will be going up by the next time I need more. Guess I have been lucky as I see Amazon is $88 and Summit is at $113.Do you buy if from Summit? I'm living right here where it's been made for all these years and no one local stocks it.
If Kendall became Penn Grade, what is the Kendall that’s on the market now
