lewtot184
the stock avs is an emissions carb. the idle circut is too lean, especially automatic trans carbs. fix this first. you'll be surprised at the difference.
I calculated compression to be at 9.5. Motor was decked, .004 below deck and heads are at 75cc
I would imagine the vacuum will increase as I increase the idle. So I guess that brings up another question. What is typical for idle rpms? Is 800-850 typical for non stock cams?
evidence that what was said earlier is the case here -Idle mix screws are as far out as they are going to get.
