Cam break in question.
1967coronet
8:20 PM
Iowa
My new comp cam instructions advise 260/270 lbs. open spring pressure at break in.
My crane springs # 99839 are advertised as 280lbs open. Is that extra 10lbs going to trash a lobe ? or do I need to switch back to the oem/stock springs for the break in.
I have not had to break in a cam in 40 years and a lot has changed, used to just Lube them in STP and fire them up dbl springs and all, never did wipe a lobe.
I am using the comp cams install lube and oil additive this time.
290# is the maximum upper limit we use on the Dyno for Flat Tappet Cam run-in....260-270# preferred and with lots of Zinc in the Oil. We typically remove the inner V/Spring to accomplish the lower spring pressure for Flat Tappet Cam run-in.
Today's Oil is much different that Oils of yesteryear, NO additives as banned by the epa, and Today actual "Break-in" Oil from LUCAS etc is highly advised.
260-270# open V/Spring pressure should run-in just fine, keep the rpm up between 1800-2100 rpm(varying a bit to through Oil different places) for 20 minutes, and again, Lots of Zinc additive in the Oil, or actual High-Zinc Break-in Oil.
best to use a break in oil blended by a blender
lower dispersents and detergents helps from washing away the EP
do not add zink to an SN oil
Brad Penn is a grade 1 oil with additives
a non or low detergent break in oil would be best
no synthetic for break in
