Paul_G
- 2:18 PM
- Dec 24, 2013
- Surprise, Arizona
1973 Charger. The electrical switch on the proportioning valve is closed turning on the brake warning light. Removed the switch and it checks good, toggles from open to closed when plunger is depressed. Looking through the switch hole I can see the spool, and it is off center. Is there any way to get it back in the middle where it should be?
I am rebuilding the entire brake system. Everything is new except the proportioning valve.
