- 11:53 AM
- Dec 10, 2013
- West Central Indiana
Carb pad top from Mopar M1 plenum I cut off with a fiber disc on the Bridgeport. I needed the lower half of the plenum to weld a plate on for a Bircatcher.
This piece would eliminate a lot of work if you wanted to make a custom homemade 2 x 4 intake.
Multi pattern holes for inline, or sideways mounting 4150 carbs.
There is a casting flash line on the inside that needs ground off in the last photo. It is not a crack, or breakage, and will grind smooth easily.
$50 shipped to you in the 48-states
Tom
Tom
