QQBlue1
I am working the bugs out of a 383 that I did not build and a smallish edelbrock type of carb that I did rebuild, less than 600 cfm.
1. The truck (67 D100) was starting and idling fine at lower altitude. I drove it out to Colorado and leaned out the fuel by changing out the jets and matched them to metering rods, and changed to the yellow step up springs. The truck was running much better, plugs looked good etc . . .
2. The next day it would not start even if I primed the carb. I did a series of checks, suspected a spark issue and put an old single point distributor back on. It fired up three times in a row but then failed to start again. I put the new distributor (a magnetic pick up unit from summit) back on and now the truck will start as long as I prime the carb. The charging system is fine.
3. The fuel pump and filter are new, the floats are adjusted to edelbrock specks (which may be my problem since it is not an edelbrock). The bowls are not dry prior to cranking, they have fuel in them. There were no choke issues at either altitude.
4. I messed with the air fuel mixture and discovered that if I wind the screws all the way in, the carb keeps running. I must be pulling air in from somewhere, but that said, I'm fairly certain that problem was present prior to this incident.
5. I feel like buying a new carb . . . . but maybe I'm missing something obvious? I haven't replaced the starter, but I don't suspect it is bad. Any advice would be appreciated!
