1967bperko
- 2:30 PM
- May 15, 2024
- jefferson township pa.
I ‘m rebuilding this Carter AFB 4barrel carburetor,model 4131S.The current accelerator pump channel has a check ball and seat at the bottom that has a tiny spring inside of it . How do you replace the check ball without damaging the tiny spring and the tiny retaining tabs ? Could the check ball be replaced without the tiny spring assembly if it gets damaged ,and will the carburetor perform ok without it? Please advise, Thank you!
