Why? You really do not need more. What camber did you end up with?What's the best caster you all have gotten and what setup? I'm running a Gerst setup and the best I could get was 3.1 and 3.4...I was hoping for more.
I've done better than that with stock A arms & offset bushings.... Last one I did was over 4.5 on both sides... But FWIW 3.0 should drive pretty good....What's the best caster you all have gotten and what setup? I'm running a Gerst setup and the best I could get was 3.1 and 3.4...I was hoping for more.
Camber was about -1 on both sides, its the caster that I want for speed and handling stability..Why? You really do not need more. What camber did you end up with?
With my red Charger, I was able to get 5.5 on one side and 5.0 on the other with stock arms and offset bushings.I've done better than that with stock A arms & offset bushings.... Last one I did was over 4.5 on both sides... But FWIW 3.0 should drive pretty good....
Interesting, I'm just about an inch in the rear on mine tooWith my red Charger, I was able to get 5.5 on one side and 5.0 on the other with stock arms and offset bushings.
Keep in mind....a car with a jacked up rear end will reduce the caster that you can get. I have my car set with a very slight rake, about 1 inch higher in the rear.
What speeds do you intend to run? And where do you go to run those speeds?Camber was about -1 on both sides, its the caster that I want for speed and handling stability..
Thank you that's great info...![]()
Finally! 70 Roadrunner going to "the old guy" for its 2nd ever alignment. QA1 everything w/SPC UCAs
I had a lot of systems and parts replaced on my Roadrunner about 2½ years ago, and I had the all new front suspension aligned at a shop close to the shop that did the work on so many different things on my car. About a year and a half ago, I noticed the car was "train tracking", following the...www.forbbodiesonly.com
