Changing over a 360 from 2 barrel to 4 barrel?
Ominous
11:05 AM
Shelbyville
I want to ditch my stock lean burn and 2 barrel carb set up for some hungry 4 barrel power, what is the parts list needed for such a feat?
not much, be ready to plug a few vacuum lines. carb/intake/air cleaner, you will have to extend the throttle cable, re route the fuel line. you can make the brackets work or find some off a factory 4 barrel car/truck. i did this with my 400 2 barrel using a 383 intake. please chime in if i missed something here fellas
Thats pretty much it. The fuel line wont need that much rerouting though. I did it on a 318 and all I had to do was get a new fuel line from pepboys for around 5 bucks. Make sure you get your transmission kick down correct though! Itll fry your transmission if its not done properly
This is what I use for the swap & it takes the guesswork out
The throttle cable bracket & kickdown kit (Uses factory Chrysler cable) comes from Bouchillion Performance Engineering. It works with all combos that are used on our Mopars.
Even lets me use my Cruise!
thats quite the carb spacer you got there, is that a 2"
