TexasRoadRunner68
I have a crusty 68 I have been working on. It needs the a small section of the driver a pillar patched on 2/3 sides. I have a donor from a 70 roadrunner. My plan was to remove all the spot welds, separate the panels, blast/primer the inside and mig or tig them onto the car one section at a time. Preferably just patching vs replacing the lower part since I might not pull the cowl.
My question is whether this pitting in the donor can be reliably filled with dura glass or filler? I know you don’t want filler over a certain depth...but I’d assume this would be fine.
This is probably an easy answer for some of you seasoned guys. I just want to do it all right to begin with.
