charging system
moparsquid
1:14 PM
spring valley ,ca.
hi i have a 62 dodge dart with the battery in the trunk ,its an optima i upgraded to a 60amp alt. but it seems that its always charging on the gauge (factory in dash) i'm only running a msd 6al,tranny cooler fan ,afr gauge and a electric fuel pump is there a way to upgrade without to much hassle
I would get a good aftermarket voltage gauge to see what it's putting out first.
Always showing a charging condition says the battery feed line is constantly putting current from the alternator output. Something on that side is loading the circuit. A defective battery might cause that. Also, if you have connected any high current load items direct to the battery or HOT starter relay terminal, that would cause this situation.
good sugestion ill check that out thanks
