"Chassis Armor" for big HP cars?
From what I can tell, he's working from a country where it isn't easy to get parts from the U.S.
It won't bother me if I never have to worry about "chassis armor." Surely these chassis stiffening kits are enough?
If it makes you feel better, no one that races , even with, 1000+ hp has that stuff on their car.
Those guys are inventing a repair for a problem that doesn't exist.
It does make me feel better, cause I want my car to be done at some point. I'm already a bit miffed to find it needs the US Car Tool stuff to keep the windshield from shattering. That's not just money, it's weight.
You can install 2" x 2" tube from the trans Xmember to the rear frame rails instead of using the Car Tool stuff......
Instead of the subframe connectors, right? I know I've seen a video that talked about how many of the connectors aren't designed well, and if they're not installed a certain way, they're less effective at best.
Instead of using the Car Tool connectors.....it depends on how fast you are going. The 2x2 square tube is very effective and even more so if you cut slots in the rear floor boards. I didn't have to do that on mine but opened up the front portion of the rear frame rails, and cut a couple of holes in the sides to do rosette welds on the tubes that were slid in and welded where the square tube was against the floors. I used 1/8" sq tube....iirc, the car tool connectors are 1/16". Maybe someone will respond to how thick the CT's are. I've had a couple of fast drag cars done without the CT stuff. My first car ran mid 10's and another was high 9's. The 10 second car had a 6 point cage in it but the 9 car was 10 point.
Have to agree. We went with 1/8 wall 2x3 cut in the floors, all the way through the rear frame to the relocated spring pocket. Now I like the idea of Birdsong's, going through the trans x member to the front rail..
