Gospel Runner
I just hooked up my cheetah shifter to my 727 transmission. I put the tranny manually into park then adjusted the end of the cable to match up with the hole in the tranny lever. When I shifted into reverse from inside the car, the lever did not go into reverse. Then I tried to put the tranny lever manually into reverse with the shifter in reverse and I adjusted the end of the shifter cable to match. I shifted into park and the lever did not click into park. I need an additional 1/8 inch of adjustment or so. My question to those of you who are using this set up is, is there another adjustment that I can make to get this to work? I would appreciate any suggestions. Thank you!
