SOLD cleaning out the garage
chooch
10:02 AM
pixburgh,pa
Feedback: 6 / 0 / 0
cleaning out the garage & the extras need to go!!!
-fresh rebuilt with brewer parts18 spline hemi 4 speed case date april of 1972 with B/E tail housing $1500
-fresh rebuilt with brewer parts 23 spline 4 speed case date c1965 B/E tail housing $1000
-new mopar perf hemi cross ram never used or mounted $600
-mopar b/rb purple cam new p4529318 .533 lift $125
-very rare edelbrock str 14-6 intake uncut or modified $700
-a12 air cleaner assembly with filter,base plate is a repop fiberglass piece $300
-D440 HP2 build date 10-11 & cast date 8-26-67 bare block with caps tanked & magged standard bore $700
-426 street wedge bare block with caps & heads no casting dates build date 3-21 tanked & magged standard bore $700
-E383 hp from a 68/69 cuda very rare A body engine with caps correct heads ,crank ,intake, water pump & the hard to find drivers side motor mount & early A body K frame.
Cast 9-26-67 / build date 8-21 tanked & magged standard bore $2k for everything
-A body 440 drivers side motor mount $150
-classic air complete a/c conversion including rebuilt heater box for 68-70 mopar b-body everything is new or like new. This set up is the only complete & easy to install unit on the market $1200
-B body adjustable steel strut rods $100
-B body aluminum strut rods $150
-sure grip with 3.23 gears $250
- sure grip no gears still has ring gear installed $150 SPF
- sure grip no gears $ sold
-489 case 3.55 gears sure grip $ sold
-edelbrock performer #1407 750cfm square flange, manual choke like new $175
-mopar B1 heads,valve covers, 2 intakes & b engine spacers all new or like new just been sitting a while $2500
-edelbrock torqer 383 intake in great vshape $75
-68-69 b body dana never cut complete but taken apart with 4:10 gears $1200
you have mail from me too. Interested in a sure grip unit. I can arrange for local pickup too.
......Re: 440 "standard bore" meaning just needs clean-up honing before build or more ?
......Re: 426 street wedge - what heads ? Year - 63 (for 64), 64, 65 ???
Top ridge on either block?
Rust in journal areas or any area of moving parts?
Pls provide zip code to determine shipping.
Thank you.
just a clean up honing & no top ridge on either. no rust or atleast anything to worry about.
the 440 has a maltese & X on the pad for -10 crank.
the 426 heads are nothing special but i'll have to dig them out to check the dates.
i'm in pa 15025
pm me your email address & i'll send you some pics
Is the Classic Air the "perfect fit series elite " ? Is it the one for "factory air" ? Thanks.
Wish that torker was for a RB (440),
ive been looking for one.
I wanted to say thanks, I backed out on the suregrip but he did everything right as a seller! I just ran out of money...:(
what air cleaners do u have? what all comes with the a12? there 4 bbl air cleaners aint they? im looking for a dual snorkle or a air grabber style for a 4 bbl
hibbidy skibbidy
-mopar B1 heads,valve covers, 2 intakes & b engine spacers all new or like new just been sitting a while, these are originals & bare $2500
UPDATED LIST
TO THE TOP WITH CHANGES
-mopar B1 heads,valve covers, 2 intakes & b engine spacers all new or like new just been sitting a while, these are originals & bare $2500 obo
-edelbrock torqer 383 intake in great shape $75
-68-69 b body dana never cut complete but taken apart with gears $1200
Can you e/mail pics of the B1 set up to email deleted
INTERESTED IN DANA WHAT GEAR IS IN IT N CAN YOU PM ME YOUR ZIP TO SEE HOW FAR THE DRIVE WILL BE. OR EMAIL ME AT email address not permitted in ads with pics ninfo
TO THE TOP WITH CHANGES, these would make perfect gifts under the kwanzaa tree!!!
