paul1969cars
They pointed out i had wrong linkage which was correct so changed that to rule that out. Still make noise. Will remove tranny and see
After the linkage was corrected, the noise only occurred when there was ZERO play at the end of the clutch fork. When the free play was loosened up, the noise went away. The buzzing/grinding sound heard is the fingers on the pressure plate hitting the springs in the clutch disc from over-extending the pressure plate. It has nothing to do with the pilot bearing.I think no matter what, you are probably faced with pulling the transmission again and inspecting/measuring everything. A real pain. Did Brewers have any ideas?
Thanks Dan. I will put it up in lift and see if that happens. If you’re correct. How do you stop the over extendingAfter the linkage was corrected, the noise only occurred when there was ZERO play at the end of the clutch fork. When the free play was loosened up, the noise went away. The buzzing/grinding sound heard is the fingers on the pressure plate hitting the springs in the clutch disc from over-extending the pressure plate. It has nothing to do with the pilot bearing.
Strange that this is the case because I just replace everything with the same setup as before. Dont know why its has this extra travel now
