column shift to slap me silly stick
Armyvet25
9:09 PM
Lorain, OH
couldn't find the info I was looking for, so if a re-post of similar question/answers...sorry.
71 charger, original column shift, purchased steering column, center console and slap stick with linkage.
1) Does any one sell the brackets to weld or bolt etc to the tunnel, under the tunnel, on the trans or where-ever?
2) Have you made your own, got a how to write up?
3) Anyone do a custom cable shifter setup either modifying the slap stick or use other shifter?
Thought I'd check to see if anyone has done this before I start with fabricating and welding and drinking way too many beers...is that even possible :rofl:
Rich
in case I need to fabricate my brackets, anyone got a 360 view of a (B-body 71-74) having their carpet out like this pic?
The slap stick is a rock solid shifter beause of the manual linkage. I have never heard of a cable conversion nor would I want one. You need to start a Parts Wanted ad for the brackets. There is a good chance someone has a parts car and the top of the trans tunnel can be cut out for your needed parts.
