Column shift w/headers? 65 belvedere
Hosehead
6:17 AM
Springfield Mo
Hey guys, I was wondering if anyone has used a 66 column shift steering column with mechanical shift linkage and headers in an early b? I was looking at either Tti or Dougs. Just curious about fit. I also have the Schumacher motor mount brackets that adapt a 440 to the original 318 poly k-frame. The car is a 65 Bel2 and I have a '71 440 and 727 trans. I know it's a reach but I thought I'd ask. Thanks everyone!!
I'm using a three on the tree column on my 67 R/T I just removed the shift lever and cut off the levers that connect to the linkage that went to the transmission. It clears the headers with no problems.
I put a set Schumacher Tri Y headers on my 383/ 67 Coronet, It has the column shift auto set up, all oem shift linkage.
know your looking at other headers but I just wanted to pass along the Tri Ys will work.
67 I am pretty sure is the 1st year for the colapsable column but I think the shift linkage is the same set up as 66
Thanks fellas. I was mainly concerned with the header clearing the 66 style linkage in a 65 Plymouth.(getting rid of the cable shift stuff). I think it will work though. If anyone has experience with a 65 b-body, let me know. Thanks again!
