Console lights
Same harness. Yellow plugs in along the left kick panel at the doors dome switch. Pink is a single purple wire in the main harness. It will be somewhere below the cluster area. Just look harder you will find it they all have it.
That yellow kick panel wire comes from the door switch up into the harness with no connector that I can see. I will look for that purple wire
Pink-----Pink----Pink. You unplug the yellow wire at the left door jamb switch, Plug the male end of the console harness into the switch, then plug the wire you previously removed from the jamb switch and plug its male end into the female terminal on the console harness. The pink wire will be loose so follow them from the fuse block along the harness its there somewhere.
Clear as mud.
Gotcha. Thats what I was looking for. At car now. Will look for that wire now.
My '62 plugged into behind the driver's side kick panel then routed behind the seat. Might have changed by '67.
By 66 the wires came from behind the kick panel, along the rocker frame to the rear taillight housing. Console wires branched off in front of the seats to the transmission tunnel .
Here is a picture of the harness you are missing.
1-Pink circle will go to a loose pink wire with a male plastic insulator terminal.
2-Red circle will plug into the console light harness if you have a manual console light harness.
3-Blue circle will plug into the door jamb harness male end.
4-Black circle will plug on to the left door jamb switch.
If your not worried about correctness you could tap into the pink for the dome light as it also is in the kick panel A pillar area.
1-Pink circle will go the a loose pink wire with a male plastic insulator terminal.
I just looked at a 67 coronet column auto dash with the original harness still connected. There's no pink wire at the kick panel to plug into and i didn't see a single pink wire connector anywhere. I'm guessing since mine is a column auto, it didn't come with the wiring for console. Hopefully your new harness will have it.
Post your photo.
Here are the original wires from our car. Hope they help.
This is the pic I was sent about the harness
Personally that harness looks way to short to be any 66-70 B-body except 66-67 Charger console harness. It looks more like a 66-7 Charger ONLY harness. Ask the guy for the part number on that little tag.
Dash harnesses are the same. The pink wire is not in the kick panel. It is in the lower dash area.
May used harness arrives on ups supposedly on Tuesday. I should be smarter by then. In the meantime,I want to thank everyone who has tried to point me in the right direction
I have posted pictures of our original 67 4 speed console bucket Charger. If one looks at the first two pictures, you will see the pictures of kick panel connectors. They definitely show the pink wires if you look closely, and the yellow ones.
This harness has worked for us since we bought the car in 1994. Our oldest son has a 1967 383 4 gear and surprisingly his is the same.
In future I will consider very carefully before I give any opinions depending on the query.
The point that I was trying to make is that there had to be a location where the console lights connect to the factory wiring .Pnora gave me what think is the answer. My console yellow wire plugs into the door switch and the switch wire then plugs into a jumper on that plug. The console pink wire then plugs into the back of the fuse panel. I will confirm this when my harness arrives. Getting closer and your help is well noted.
