easyrider
I've been having a few problems with my console lights that you, guys have been helping me with, but I've gotten caught up in a disagreement with a guy at the parts house. The courtesy lights on my console use a 90 bulb, which has 2 contacts and single filament. After tracing the wiring, I found a yellow and a pink wire going to the bulb and as I see it, one wire is from the head light switch to turn on the interior lights and one wire is from the door switch to turn on interior lights when the doors are opened. So, it would seem to me that the bulb grounds to the socket and you have 2 hot wire. The guy at the parts house said that one of the contacts was a ground and the other was hot, so he took a battery and put the hot to one contact and negative to the other and the bulb lit up. My thinking is that he just completed a circuit with the bulb being like a wire between the two points. Anyway, I think my problem in the console is a ground problem, but anyone out there had any problems like this? Anybody know this bulb (90) and how it works? Sorry for the tirade, but it got under my skin. I've never seen a bulb that didn't ground through the case to socket contact. Thanks for listening!
