Find a “Clutch Style” sure-grip unit from a pre ‘69. It can be from a 741 or 742 case, they are same and will fit a 489 case as well. The 2 halves of the posi bolt together and it’s easy to disassemble. Once inside, inspect the clutch plates. If they are chewed up, galled or heavily worn, replace them with new plates. You’ll have to stick your axles into the posi to make sure the clutch plates stay aligned while you tighten the case halves. Inspect the carrier bearings, they can be used again if they are clean and in good shape ( no pitting, galling, heat damage) . On mine, I take the SG unit to a machinist and have him check the runout of the ring gear mounting face on a lathe. I’ve had him cut up to .005 off the face to true it up. Makes getting consistent backlash adjustment way easier. Once everything checks out, install your ring gear , install carrier , install bearing cups, caps and carrier adjusters. Only moderately tighten upper carrier cap bolts, install lower bolts hand tight. Adjust left carrier adjuster until you have about .001-.002 backlash. Then tighten right adjuster until you have .005-.007 backlash. Check backlash in 4 places. Should be consistent . Torque carrier caps to spec, and install in car.
