maddart
Coolant issue:
Drove home the car from its maiden voyage last night and the temp gauge read 150 degrees.(Thought this was strange) pulled up in the garage and noticed the oil pressure was virtually at 0-5psi. After shuting it down i opened the hood and you could cook an egg on the valve covers/radiator/air cleaner. The oil was as thin as water. Today i opened the radiator and it is full.This is a new rebuild and has been running 190 degrees around the block and for tuning in the garage.
Airlock?
Intermittant thermostat?
I removed the coolant this morning to shorten up my heater hoses (Put new hose brackets in) and filled radiator up half way. The front of the car is in the air about 4" up. I went to start the cnet and all i got was a click. (Dead battery)
Electrical issue:
The battery is from 06. Previous owner.
Driving home the headlights and dash lights are very dim.When i put the turn signals on the electrical (Water/oil) gauges move in rythum to the blinker.
New bulkhead connectors and headlight switch.
Grounds are very good.I added an additional ground point to the car as well.
The car has a VR-263 regulator that i cannot find any info on.
How can i test the VR and altenator to see if they are working properly.
Should i have a different VR? Car has Mopar orange box ignition.
Airlock?
Electrical issue:
