Coronet/RT/SuperBee dashes questions?
Mocajava
12:34 PM
Brighton Colorado
I have a 69 Coronet 440 w AC and a perfectly good set of dash pads. I want to modify the dash to include an insert with better/larger gauges and wonder if I can retrofit an RT or Super Bee lower and middle dash pad onto my dash to gain the extra room above? I can't seem to find anyone that remanufactures the lower and middle dash pads for 69 Rt's or Bees....am I not looking in the right places? Will 69 RR or Charger lower and middle pads work for my mock up? I was hoping to find these pads to start the mock-up but if I don't find any the whole concept made be down the tubes. Any help would be appreciated... I tried search and didn't come up with the answers I am looking for. Hoping the experienced ones in this membership could steer me in the right direction. Thanks gentlemen.
The lower pads are not reproduced. The charger,superbee pads are the same for the rally dash
At PG Classics they told me the 69 Charger lower pads they make DO NOT fit the SuperBee or RT. I would much rather believe you then the Pakistani guy at PG Classics. If the charger pads would fit I can keep moving on this build with the dash I want. Thanks you sir!
I tried to source the same pads during my resto - unobtanium unless you go used.
This is what I did to put bigger gauges on my '70 Coronet R/T non- rally dash. The clear plastic speedo lens was ruined on the ends. It looked like someone tried to clean it with sandpaper. I still like the long sweep speedo's, and luckily, that part of it was still good.
Okay, I would like to get this straight BEFORE I go order and ship stuff that won't work. The 69 Charger and 69 Super Bee use the SAME lower left and middle dash pad.....correct? Not having access to a 69 Charger here, I have no way to compare.
They are the same. Same dash, same instrument cluster ,same glovebox door, same upper pad
and same lower pads
