Correct Holley 4barrel Carb for 1970 383 HP
ramcharger
The '70 Coronet in your avatar doesn't have the ramcharger (fresh air; N96 option) hood.
Are you doing an upgrade to your car or working on a different car with the ramcharger?
Just curious.
Holley R4369-A is part number 3418 562.
I can check my old Dodge parts book tomorrow.
@moparnorth
Just curious.
I am
Just curious.
i am doing a super bee clone
...70 383 HP, b body, automatic tranny, ramcharger...
Yes with air...
I don't believe it's possible to have the "correct" carburetor as this configuration was invalid to order from what I understand. The fresh air base occupied the area where the AC compressor would go.
So I think you have two choices - neither of them "correct"; one a Carter (AC car) and one a Holley (Ramcharger car). Someone else more in-the-know can probably elaborate more precisely and/or from experience than I can. Image below is a cut/paste from the parts catalog of the two that seem closest to me. Neither are N95/California. I'd guess the Holley?
*Edit - I see a couple more possibilities for 4bbls; the 4369A (3418 562) is a 'Superbee' Orange 335hp 089 AC-Auto engine's (but not N96) Holley I believe?
Thank you for the info very helpful also if a carb cannot be found for my customs setup which one would you recommend
On my Bee I was running a Holley 750 DP, 4 spd
What would be a good chose w/o California emmisions
The first order of business is to figure out how you're going to fit the ramcharger setup on a car with air conditioning. See post #28...excerpt:
Also, you didn't say whether or not you have Automatic Speed Control on your car, but it isn't compatible with the Air Scoop Ramcharger Hood either.
H51 air conditioning not available w/Air Scoop Ramcharger Hood.
N96 Air Scoop Ramcharger Hood not available with air conditioning or Auto Speed Control.
N88 Automatic Speed Control not available with Air Scoop Ramcharger Hood.
The above pic is an excerpt from one of the images found in the link below.
Post in thread '1970 coronet trim packages? anyone' 1970 coronet trim packages? anyone
No AC with Fresh Air setup I believe from factory. You will have to notch the air cleaner base. Also you have to have a 3 spd wiper motor
If wanting AC you can change the compressor like they did on this car
