MoparMur
- 9:15 AM
- Apr 21, 2018
- Lethbridge, Alberta, Canada
Hey guys need some help. My son's '67 Belvedere has a '70 440 installed. We have it out to repair an oil pressure problem, and discovered the oil pickup tube cracked at the threads at the block. This engine was built up years ago by someone, and they installed a 1/2" NPT pick-up tube. I once had a couple '70 U-code Challengers, and they of course had heavy rods etc. and the longer sump oil pan. His oil pan looks all the world to me to be the same dimensions as mine were, and I'm thinking the stock-style Hemi pickup tube would work, correct? I'm going on memory here that the Hemis used the 1/2" tube as far as I recall. Any ideas what pickup tube we need, part number, supplier, etc.? BTW no numbers stamped on his oil pan. Thanks in advance for any help.
