Creative Fix for Spinning Frame Nut During Steering Gear Install
LoneCabbage
New Member
6:56 AM
Orlando
Hey all,
Long-time lurker here—finally joined and wanted to contribute something. While doing a front disc brake conversion and suspension rebuild on my ’70 340 Cuda, I ran into a headache with the steering gear install.
At the last minute, I decided to rebuild the gear and coupler—figured I might as well finish the job right. When I pulled the steering gear, I noticed the lower tack-welded frame nut was spinning. Not ideal, but manageable with a wrench.
Then came the real problem: while reinstalling, the upper driver’s side nut broke loose and dropped inside the K-frame. As many of you know, that nut is nearly impossible to access—especially with the gear in place.
I started looking around forums, and the common fix was to drop the K-frame and cut an access hole to re-weld the nut. After the car had been down for a couple of months and was so close to being done, that was the last thing I wanted to do.
So... I cracked a beer (because all great redneck engineering starts with one) and came up with a workaround that actually worked great.
Here’s my workaround:
  • Cut the closed end off a cheap 13/16" wrench.
  • Applied JB Weld to the nut and the inside of the wrench head, and let it set up.
  • With some careful finger work, I was just barely able to push the nut/wrench assembly into position and start a bolt to hold it in place.
  • To hold it there while finishing the install, I shot expanding foam into the cavity.
  • Once cured, I removed the bolt—the nut and wrench stayed perfectly in place.
  • Reinstalled the steering gear, and the wrench stub locked itself against the K-frame while I torqued everything down.
I know it’s not a “proper” welded fix, but it worked perfectly, was quick, and didn’t require tearing everything apart. Maybe I’ll address it the traditional way when I eventually pull the engine. For now, I’m back on the road—and that’s what matters.
Hope this helps someone in the same boat!
Yep, that would classify as redneck for sure, lol. Had the same thing happen to me once as well. I have a hoist, so propped up the motor and removed the k-frame. Cut a hole, welded in a new nut, welded my cutout back in, a little grinding, spray bombed some black paint, and reinstalled. Kind of a design flaw by Ma Mopar imo.
