custom rear brake line
69clone
6:36 PM
Tennessee
I have a dana 60 out of an old ford 3/4 ton. I'm trying to determine how to run brake lines. The original vent is on the passenger side. Do I tap a new one on the right side or run a line over there and T it from there? or does the T really need bolted in? opinions?
Don't think vent location matters. Good luck.
Thanks, I should clarify I am wondering how to secure the t that connects the hard lines to the rubber line if the vents on the other side.
You can't either drill and tap the housing or tube. Or, use a bracket and bolt it under a cover bolt.
Mount the bracket for the flex hose on passenger side? Extend the hard line to passenger side.
