Cylinder head bolts for a 318 Poly (A-Block)
Furiosa
New Member
9:15 AM
East Tenn
Can't seem to find aftermarket cylinder head bolts for my 318 Poly. What are y'all using?
Hi
In all the years that I've been working with Polys I've re-used the hardware. I check the bolts by ringing them (a tap on the side of my anvil if the bolt "rings" it still has it's temper and then I check the thread with a thread pitch gauge to ensure nothing is distorted. If it passes I re-use it. However I never re-use connecting rod nuts , I use the longer "GM" style. So far no problems or failures!
