Theslo1
- 8:20 AM
- Apr 16, 2013
- Charlottesville Virginia
This is not a b-body, but I trust the information here best. I saved a d200 from the junkyard, I need to swap the old d60 for a replacement I already have. I wanted to do a spring under conversion while I was at it to lower the truck, Its only 2wd. I don't see a way to make the old u-bolts work, but I think I have a set that look heavy duty from another truck. Problem is they don't match the holes in the shock plate perfect, they are a little wider. My question: Is it ok for the u-bolts to be a little larger radius than the axle tube? This will be a dual rear wheel with a big block and maybe a 4 speed if I can find the parts. Would a caltrack type system be a good or bad idea. I'm not worried about traction, four tires should take care of that, axle wrap is my concern.
Thanks for the input
Eric
Eric
