DC MP and FSM cams compared to Detroit grinders
wyrmrider
10:01 PM
los angeles
Melling, Elgin, Wolverine, Summit, Crane, Cam dynamics , Edelbrock, Engine Dynamics
and MOPAR Cams
Sorted by MOPAR Duration for DC/ MP and factory cams with SAE duration (.006 at the valve or .004 at the seat with 1.5 rocker approximately placed in the list
all are in the same order but the board software will squeeze out white space
Lift (lobe lift) adv or .004 Duration - seat timing - at .050 timing LCA icl excl
Crane .904 lobes H2 street and strip H3 have higher acceleration = will need more spring
Compare Crane .904 lobes- which are fairly mild with the Detroit Grinders Grinds
372/400 264/274(50) 180/192 -20 21 24 -12 114 LCA 110 ICL 108 EXCL Elgin 577S Engine Dynamics S-645
351/351 no adv given ` 181/192 109LCA Sealed Power CS-645 273-318 stock
.375/.375 240/240 188/188 114 LCA Cam Dynamics 1500 240H14 1000-3000 1500-2000 cruz
392/390 192/192 Cam Dynamics 15202 383 4bbl 315 Hp 2268405
400/427 248/260 192/204 112LCA Crane 693971 H-248-2 HMV-248-2-NC
.405/.405 248/248 200/200 112LCA Cam Dynamics 15001 248H12
368/398 250/260 184/194 110LCA 105 ICL-115EXCL WG-1183
410 (273) 278 (59) 203 -7 30 32 -9 109 LCA 108 ICL 111 excl Elgin E-626-S ED s-645
TRW-TM 627
.410 /411 .273/.274 no adv 197/199 111 LCA 114 108 2806283 Wolverine CS 4115 marine
.427 260 204 110LCA 260H10 Cam dynamics 15003
398/420 (265/280 ) 260/270 (45ovlp) 194/204 8 22 37 13 110 LCA 105 ICL 115 excl Elgin -983P WG 1184
434/431 260/268 206/209 WG-1121 395hp 413 Wolverine stock B/RB
427/454 260/272 204/216 112 LCA Crane 693901 1,500-4,500 H-260-2 HMV-260-2-NC
.372/.399 264/275 12 72 57 38 (50) 180/192 -20 20 24 -12 109 LCA 110 icl 108 excl Melling SPD 20
.458 (.305 lobe) 264@.004 202 @.050 120@200 Jones Special *10 degrees earlier close than stock 440 434 284 206 ??? 74 IC stock 440
.440 266 210 110LCA Cam Dynamics 15004 266H10
459/480 268/272 212/220 112LCA Crane 693511 (some crane shelf grinds are .904- check
459 268 212 127@200 57 intensity Crane .904 H3 race only *8 earlier close than 440
420 270 204 110LCA 106 icl 115 excl WG 1105
420/420 270/270 204/204 4 28 36 12 110LCA 106 ICL Edelbrock 2177 16” vac idle -5500
"Produces 305 ft.-lbs. when matched with #2176 intake and stock heads."
420/443 270/280 204/214 112LCA 107 icl 117excl WG 1116K
454 272 216 110LCA Cam Dynamic 15005 s 272 H10
455 272 (52) 216 3 34 33 4 110LCA 105 ICL 115 excl Elgin 1789P
454 272 216@050 110LCA SUM-1789 largest stock engine cam works best with 9:1 and gears 1,500-5200
454/454 272/272 216/216 110LCA 1,800-5200 Crane 15005 272H10
454/480 272/284 216/218 112LCA Crane 693941 2000-5000 H-272-2-NC “Max Velocity”
431 274 202 114 @200 H2 H-202/2880 can close intake 5 degrees earlier than stock 440 cam
480 276 220 136 61 Crane .903 H3 H-220/320 note difference .903 makes
can close intake 4 degrees earlier than stock 440
441 276/288 (54) 218/228 0 38 53 -5 109 LCA 109 ICL 119 excl Elgin 1223P
441 276/288 218/288 114LCA 1,800-5500 Summit 6901
480 276 220 136 70 *4 H3
454/454 278 /278 222 110LCA Cam Dynamics 278 H 10
410/412 278/282 198/199 111 LCA Melling 23103 idle-4,500 (rounding)
410/411 278/282 16 82 61 18 (34) 198/199 15 33 27 8 111LCA 114 icl 108 excl
Melling 23103
421/444 278/288 204/214 112LCA 1,200-5000 SUM 6900
421/444 (.281/.296) 278/288 (59) 204/214 -6 30 43 -9 (-15)112LCA 108 ICL 116 excl Elgin 937P SP-CS 1089R 1500-4000
420/443 (270/280 adv)? 204/214 112LCA 107 icl 443 excl WG 1116
420/443 278/288 27 71 76 32 204/214 5 29 44 10 112lca 107 in 117 excl Melling MTD-1
467/494 278/290 222/234@.050 114LCA 2,200-5,200 Crane 693801 H278-2 HMV-278-2-NC
340 HP CAM here you can compare MOPAR duration which is close to .008 with .004 data
429/444 (286/296 279/289 .004 (50 ovlp)210/220 -8 37 46 -6 (-14) @.050 114 LCA 112 ICL 116 excl E-578-S` S644 SP-CS-644 Melling SPD-22
429/444 .2861/2958 279/290 (50)trw TM578 sp-cs 644 2899206 340 CAM 1500-4500
429/444 286/.296 210/220 114 LCA 110-118 Wolverine CS 4109 marine (LH available)
429/444 {268-276 MOPAR DEGREES } 210/220 WG 1118 oem #4214671 275hp 340
429/444 279/289@.004 209/220 114LCA 112 Icl 116 EXCL Elgin E-578 s
Timing 20 79 79 30 SAE/ .004 -8 37 36 -6 @.050
429/444 279/289 20 79 79 30 (50) 209/220 -8 37 46 -6 114LCA 112ic 116excl
mellling spd-22
429/444 210/221 Crane 963901 276hp 340 114lca Cam dynamics 15002 220-221 H14
421 (.280) 280 (58) 208 -3 31 39 -11 (-14) 111 LCA 107 ICL 115 excl Elgin E-938-P
SP cs 1006R 1500-4000
443 (295) 280 ( 60 ) 214 1 33 41 7 110 LCA 106 114 Elgin E-1087P WG 5023
460/450 280/288 224/232 112LCA HIT-280-2-HIT
443/465 280/290 214/224 112LCA 107 in 117 excl WG 1161
stock early B/RB 260/268 adv 284/293 SAE/ .004- 206/209 or 208/210@.050
431/429 283/296 208/210 113 LCA 110 ICL 116 excl Elgin E-327S
-7 33 40 -11(.050) 22 74 74 39 SAE (.004) 2894/2870 lobe lift
intake close in Bold SAE is .004 lobe lift with 1.5 rocker (.006 at the valve)
434/431 207/210 Crane# 967981 365hp 426 hp 2268405 113lca (not in current catalog)
434/434 260/268 206/208 113/110 Howards CL727511-13 365HP/440 cam (#2532190).
434/431 284/293(SAE) 206/209 113LCA 110 ICL 116 EXCL Sealed Power CS-327 Melling SPD-11
434 284 206 ??? 74 IC stock 440 note how DC 260 is fatter @.050
430/430 284 @.004 212 @.050 115@200 Direct Connection “260” cam P4286669 MEASURED
430/450 {260/268 advertised .008) 221/228@.050 110LCA P4452759AE newer grind
456 284 212 125@200 .904 H2 212-3040 street strip same duration as stock 440
480/480 284/284 228/228 112 LCA 284H12 Crane 150062 3000-6200 cam dynamics 15006 26-55
501 284 228 145 .904 H3 228-334 race only same duration as stock 440
445/445 (303/303) 284/284 (68) Engine Dynamics 1028 Melling RYB 20)
.458 .305 284 64 olap 218 34 44 65 110LCA 105 ICL 115 EXCL Elgin 1042P WG 1141
480 (320) 284 61 ovlp 228 7 41 51 -3 112LCA 107 ICL 117 EXCL Elgin E1798P
480 284 228 112LCA Cam Dynamics 15006 284 H12 2800-5800
.480 285 228@.050 112LCA 2,500-6,000 SUM-1798 :)1+ 2500 stall gears
“The tight lobe separation will boost your torque, throttle response, and mid range power for exciting action at the track and on the road. “
.473 286 226 106LCA Cam Dynamics 15007 2600-5500
480 (320) 287 69 ovlp) 231 8 43 46 5 109 LCA 107 Icl 11l excl Elgin E-935-P
458/465 288/292 226/230 110LCA H-288-2 Crane 694301 2,500-5,500
443/465 288/298 32 76 81 37 (69) 214/224 0 34 49 5 112LCA 107 in 117 excl
Melling 23203
444/466 288/298 214/224 112LCA Melling 23203 1,700-5,200
442/465 .295/.310 288/298 (69) 214/224 (-5) 112lca Sealed Power CS 1019R 2200-5200
444 289 220 Stock 340 exhaust
447/450 290/290 222/232 112LCA Cam Dynamics 1983 15008 290H12 2500-5500
494/494 290 /290 234 /234 112LCA Cam Dynamics 15012 290H12 1991 3200-6200
448 (298) 290/319 (87 ovlp) 222/232 4 38 53 -1 112 LCA 107 ICL 117 excl elgin 1858-P
447 (.298) 291 67 ovlp) 4 39 48 -5 112LCA 107 ICL 117 excl Elgin 934P
522 292 236 153 Crane .904 H3 race only
480 294 222 136 .904 H2 street strip
480/480 294/294 222/222 106 LCA H222/3200-6 Crane 690141 2800-6000
502/525 294/304 238/248 114LCA Cam Dynamics 15013 294-304 H14 3200-6200
444/466 296/311 (69 ovlp) 214/224 -1 35 48 -4 112LCA 108 ICL 116 excl Elgin E 936-P
450/476 (300/327) 298/308 (102) 9 43 58 4 112LCA 107 ICL 117 EXCL Elgin 933P
465/488 298/304 37 81 85 39 224/304 5 39 54 0 112LCA 107in 117 excl Melling 22303
480 (.320) 299 (70) 225 (29) Sealed Power CS177R Engine Dynamics 1149
480 /480 300 230 109LCA Cam Dynamics 15009 3000-6200
502 .338 300 (84)Engine Dynamics 1196
543 300 244 161 @200 H3 race only
447 302 214 74 440 Magnum Intake for reference
.504/528 302/312 232/242 114LCA H 302-2 Crane 694561 CCH-302-2-NC
504 304 232 146 Crane .904 H2
554 304 248 166 Crane .904 H3
453 .302 304 (88) 226 7 39 43 3 (10) 108LCA 106 ICL 110 excl Elgin 1146P
453 .302 304 (88) 225 (9) Speed Pro CS 178R ed 1177 McQ CMR625
500/500 306/306 246/246 106LCA Cam Dynamics 15010 3000-6500 no power brakes-stick
447/450 306/316 222/232 112LCA 107 icl 117 excl WG1007K
470 308 226 106LCA Cam Dynamics ¾ race :) 15007 308-06 HTQ 2,500-5500
564 308 252 170 Crane .904 H3 race only
488/510 308/318 234/244 10 44 59 5 (15) 112LCA 107 icl vac 10” Edelbrock 7177 1500-6500 : 417 HP & 397 ft.-lbs. with #7176 intake & #60779 heads.
503/525.335/350 310/320 SAE 99ovlp Solid) 21 47 62 16 @.050 108 LCA 103 ICL 113 EXCL E-985P
.528/.552 312/322 112LCA Crane Power Max 3200-7000
.528/.552 312/322 242/242 108 LCA H312-2 Crane 694571 3,500-7,000 CCH-312-2-NC
575 312 256 174(200) crane .904 H3 race only
528 314 242 156 H2 street strip
585 316 260 178 H3
464 324 225 Magnum Exhaust for reference
552 324 252 166 H2
500 328 246 106 LCA Cam Dynamics 15010 ¾ race 328-06 HTQ
576 334 262 176 H2
